General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
I can see the light at the end of the tunnel...but still need help!
Old Aug 31, 2009 | 02:27 PM
rsidner's Avatar
So I'm at the end of the journey with my EFI conversion of my '84 4runner. I have an AT wiring harness but using a manual transmission. Can someone tell me which wire for sure is my neutral safety switch cable? And can I just put this to ground and close the circuit permanently? I know that it will start when in gear but I have a good enough habit of always pressing the clutch to not screw up.
I also need to hook the speed sensor and 4x4 light from my tranny up. Does anyone have any input on this? The neutral switch is the big thing.
Thanks!
Old Aug 31, 2009 | 03:51 PM
INFINITY's Avatar
get a haynes with the wiring schematics in the back of it. they look intimidating but after a while of looking at them you will understand them. but i would do like you are saying and just jumper permanently the nss so it thinks it is in park.
where are you located i have a harness and ecu for a 85 efi 4runner.
Old Aug 31, 2009 | 04:41 PM
rsidner's Avatar
I'm in central Ohio. I don't need any wiring really...more than anything, I could use some hands-on help for like an hour or two from someone that has done this before.
I've already gotten the entire vehicle rewired...I might kill myself if I needed to re-rewire this thing.
Old Sep 1, 2009 | 10:53 AM
rsidner's Avatar
Can I just connect the ignition wire (labeled ST1 in the FSM) straight to the starter? If so, where would the closest splice point be for this wire to the starter?
Flying91
45
Apr 11, 2024 04:39 PM
Charecter1
Nov 6, 2023 10:08 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
raptor510
Feb 17, 2017 07:11 AM
Sep 4, 2015 09:27 AM
