General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Auxiliary Fusebox Suggestions
Old Jul 23, 2011 | 11:36 AM
GreenArrow19's Avatar
Greetings all,
I'm looking to install an auxiliary fusebox to provide power from the battery to a handful of electrical components. Read a few posts that covered installing one as a power source for relays but haven't found a post that used one as a power source directly to devices. It would be providing power to two engine bay lights and two phone charging ports, both of which I would like to have power even when the truck is off. Would it need to be heavier duty that the ones used for relays? It is essentially the same in practice as the one purposed for relays but just wanted to make sure as this would be my first venture into electric mods. Any suggestions of which fusebox to use would be appreciated as well. Thanks in advance!
Old Jul 23, 2011 | 11:44 AM
justin_4runner's Avatar
i would use 8 gauge wire from battery with a 40 amp fuse on it, then to the fusse block that u like, i have just used fuse holders before and taped them together for a set up but its more what u like for a fuse block.
Old Jul 24, 2011 | 09:45 AM
suncomb1's Avatar
Check out Centech or Ron Francis Wire Works on the WEB. I use a Centech 5 Fuse panel for my Auxiliary lights, Nitrous, etc. Good quality stuff.
Old Jul 24, 2011 | 09:54 AM
xxxtreme22r's Avatar
Blue Sea fuse box FTW. http://bluesea.com/category/5/21/productline/126
Also check out Irab88's build thread. He's got a pretty trick setup as well. Also using a blue sea fuse box as well as some other goodies.
primordialbeast117
Dec 19, 2015 12:23 PM
Ditch Doc
Oct 27, 2015 03:20 PM
Iceman4193
Oct 16, 2015 10:50 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
the_supernerd
Oct 1, 2015 09:20 PM
