General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Alternator/electrical problem
Old Sep 19, 2015 | 11:28 PM
SCZIG's Avatar
Any help of redirection to old post would be appreciated.
1981 Toyota pickup I thought my alternator was going bad due to battery not charging(new battery) changed the alternator and was checking voltage everything seemed fine but after running for about 45 seconds-1 minute the black wire from the alternator plug began to smoke, so i disconnected battery and shut off the truck. I was assuming the wire was shorting out some where but have traced it back to the firewall and not found anything yet. I did notice this only happens when the voltage regulator is plugged in, could this perhaps be bad and is there any way of testing it without it running? Thanks
Old Sep 20, 2015 | 02:54 AM
wyoming9's Avatar
Red face
Is the new alternator bad ??
What kind of voltage did you have with the old alternator??
I take it you don`t have the EWD for your truck I don`t have anything that old
Having the schematics would tell me how to test the regulator. .
Old Sep 20, 2015 | 07:42 AM
Terrys87's Avatar
The 84 and older trucks have an external voltage regulator. I forget where it is mounted but I think it is a black metal box if I remember right. Wonder if it the part failing.
Old Sep 20, 2015 | 09:00 AM
SCZIG's Avatar
It does have an external voltage regulator. I replaced it about a year ago. I opened it up and compared it to the old one and it looks fine. The old one had a burnt out wire on one of the coils. If the new one were bad I would assume it would look similar to that one? In regards to the old alternator I didn't check it but looking back I don't think that was the problem. I believe something is shorting out some where
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
