General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Alarm siren/speaker placement
Old Feb 4, 2007 | 08:26 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
for those of you with aftermarket alarms? where is the speaker for the siren located? ill be putting an alarm on mine soon (mainly to alert myself if something is happening) and was thinking about where the speaker would go. i cant put it where my PA is, thats too external and someone just has to cut the wires and it wouldnt make sound. are there good places back in the engine bay that are good for it? would it not be muffled too much tucked away somewhere? thanks!
Old Feb 4, 2007 | 08:35 PM
reggie 00's Avatar
Anywhere under the hood that wont cause damage or be damaged should be fine. These things are loud.
If you are worried about someone just cutting the wires they make a battery back up one that will go off regardless.
Old Feb 4, 2007 | 08:39 PM
alright sounds good. i know about the battery backup but i meant just the speaker, they could cut the wires at the speaker itself and then it wouldnt make noise even if the alarm was activated, am i correct? or are the computers smart enough to know its been cut and then they do something else?
Old Feb 5, 2007 | 07:04 AM
reggie 00's Avatar
The one i had for my Tahoe it was all integrated, siren/back up.
If the alarm goes off and they cut the siren out. it should disable the vehicle, but then there is no loud noises to make people notice someone is rewiring everything to steal your stuff.
An Alarm just keep honest people honest. It will not deter a pro.
Old Feb 5, 2007 | 04:34 PM
Merlin's Avatar
You can put the speaker/siren up against the firewall as high up as you can (assuming that you may try water crossings at some time) to keep it high and dry. Most places recommend that you point the siren down to keep water from collecting in it.
Some people have put them behind the grill facing out or down for maximum volume, but as you noted, the speaker wires can be cut. I don't know if the alarm brain can tell the siren wires have been cut, but the ignition kill should keep your truck from going anywhere (unless they are pros or really determined to get your vehicle).
Hope this helps,
Merlin
Old Feb 5, 2007 | 04:55 PM
craw4x4's Avatar
mine is in the firewall near the brake booster there is a big ope space there.
toyotasaurus
Sep 24, 2015 03:30 PM
JamesDINAN
Sep 22, 2015 05:37 AM
shisha1999
Sep 20, 2015 11:44 AM
Bawlzdeep
Aug 2, 2015 08:35 PM
jetspeedz
Jul 13, 2015 09:32 PM
