'97 4Runner keeps blowing fuses and windows wont roll down
I have a 97 4Runner that has really been giving me problems for about a month now. It has an aftermarket stereo and didn't get good reception. I had simply asked my son to see if antenna was hooked up in back. Needless to say after most of dash taken apart and various wires messed with. I have already replaced starter relay,fusible link and most of the fuses I am now to this. Windows and fuses still blowing. No flashers turn signals or hazards. Please help thanks in advance. Michelle Oklahoma City
Sounds like you got a short, check through your wiring harness and your ground points, I'm not knowledgable when it comes to 4runners but on my truck it did the same thing, put a new battery and close to 100 dollars in fuses, had a short on my O2 sensor, hope this helps, of not there is a ton of knowledgable people on here
Same problem
Hey, i recently changed my antenna on my 96 4runner and the next day i had the issue with the window motor Fuse. it keeps blowing out and im sure i didnt pinch any wiring harness.. Please post if you found a solution to this problem ASAP
Jun 1, 2021 01:51 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
