General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
84 yota pickup 2wd with Horn problem
Old Apr 8, 2012 | 03:35 PM
luddite20's Avatar
Yota wizards! My horn has never worked, and it's high time I fix it. I check the voltage at the horn and there is nada. I hooked up jumpers to the horn itself and it works fine. I don't have a diagram for the fuses, but I am under the assumption the same fuse that actualizes the hazards is the same for the horn, and the hazards work fine. I have yet to determine if there is a relay for the horn in this system. The spring loaded lead off the steering wheel makes good contacts, and the switches themselves on the steering wheel are free from corrosion. Thoughts? Helpskis? You guys rule!
Chad
Bamripzit
Jul 19, 2015 01:17 PM
Bamripzit
Jul 13, 2015 07:21 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Yota.Jay
Jul 2, 2015 12:57 PM
ibayne
Jun 26, 2015 06:30 AM
