General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
81 will not shut off when ignition switched off
Old Sep 22, 2014 | 07:50 PM
dropzone's Avatar
Fossilized
Ok got an electrical issue I hope you guys can help me out with.
Over the past few years my truck would intermittently not shut off when the ignition was shut off with the key. Now it never shuts down with ignition off. I have to step on the brakes and slowly let the clutch out. Obviously not ideal or safe.
I have traced wires (look fine), checked grounds, and replaced the switch in the column. No luck. Have not replaced solenoid or starter. Starter works fine, not sticking etc.
Any suggestions? 1981 Toyota with L52, 22r
Old Sep 22, 2014 | 08:00 PM
millball's Avatar
Does the battery discharge when the key is off after shutting down with the clutch??
Old Sep 22, 2014 | 08:18 PM
dropzone's Avatar
Fossilized
Nope. Truck has sat for a few weeks before and started right up after using the clutch shutdown method.
Old Sep 22, 2014 | 10:01 PM
vital22re's Avatar
totally a bro
Does the ignitor/coil still have 12v to it once key is turned off? or is it "dieseling"
Old Sep 23, 2014 | 03:08 AM
dropzone's Avatar
Fossilized
With key turned off it continues to run like normal, no sputtering like it is dieseling, so yes it still has power to coil based on that observation. Haven't measured power.
Old Sep 23, 2014 | 09:05 AM
millball's Avatar
Sounds as if a power source (Relay or relays??) is improperly holding in until the alternator stops producing power.
Old Sep 23, 2014 | 09:41 AM
kawazx636's Avatar
I think this your your truck's way of saying "drive me more often damnit!!"
I bet Don (Suncomb) could point you in the right direction - he always has the answers to my electrical woes. You oughta shoot him a PM
80Truck
Oct 12, 2025 07:25 PM
redneck17
Aug 12, 2015 08:15 PM
redneck17
Aug 5, 2015 10:03 AM
TDonkey
Jul 26, 2015 10:14 AM
colinmil
Jul 6, 2015 04:03 PM
