General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
'77 Toyota pickup turn signal indicator lights come on when brake is pressed
Old Mar 25, 2014 | 01:42 PM
Grendal1's Avatar
Exclamation '77 Toyota pickup turn signal indicator lights come on when brake is pressed
My boyfriend is installing a new wiring harness in a 77 toyota pickup. Everything seems to be working fine except the Yellow turn signal indicator lights come on solid when brake is pressed. Any ideas as to what may cause this and how to fix it? Please help!
Old Mar 25, 2014 | 02:04 PM
dropzone's Avatar
Fossilized
You have got a short some where. Probably in the steering column area. Bust out the test light and DMM..
Old Mar 25, 2014 | 02:20 PM
Grendal1's Avatar
thanks Here's to hoping he finds it before he loses his sanity lol
Old Dec 14, 2014 | 03:16 PM
Sdmeitzner's Avatar
Mine was similar....the driver side rear blinker came on when brake was pressed, and blinker didn't work when the brakes were pressed either. I ran a new ground from the rear light assembly directly to the frame and it fixed my problem.<br />
<br />
So, check the ground.
Old Feb 26, 2015 | 09:25 PM
cb'sYOYO's Avatar
I've had the same problem before and ended up being a bad bulb talk about pulling hair trying to figure out
Aleeex_u
Jun 5, 2016 06:52 PM
Gamble_STi
Jun 27, 2015 07:54 PM
ItsAtoyotaLIFE
Jun 21, 2015 11:45 AM
streetuner15
Jun 18, 2015 10:59 PM
infinityisfive
Jun 16, 2015 06:51 PM
