Maintenance & Repair Care and feeding of your rig
Removing Broken Inner CV Axle Shaft
Old Oct 25, 2008 | 01:39 PM
Vermejo's Avatar
When the CV breaks at the inner axle shaft extraction or teardown are the two options. The broken shaft in inaccessible by simple measures.
-Jack and support front end safely
-Remove tire, damaged CV and shock assembly (Plenty of write-ups on CV removal)
-Mark and indent center of broken shaft
-Wedge paper into the bottom of the housing to catch metal shavings
-Make sure your drill fits into the tight space at a straight angle. If the drill does not fit removal of the LCA is required. The DeWalt I used was big and had to be operated upside-down to get a straight line on the shaft
-Use a 5/16 cobalt/tungsten carbide tip bit for drilling. Drill a pilot indention with 4WD disengaged to spin the shaft and center the hole more easily
-Engage 4WD and front locker and drill approximately ½ inch deep
-Start the 3/8 tap by hand and continue with a wrench. Back the tap out every so often to clean the threads and clear metal particles, wasted gear oil will assist the tap
-Thread the 3/8 bolt and remove the shaft with a slide hammer. The Harbor Freight model I used was 3/8 and threaded directly into the shaft. Otherwise use a 3/8 bolt and slide hammer jaws. (in the tools pic note the shaft piece at the end of the slide hammer)
-Thoroughly clean the housing to remove any shavings/debris
-Change the diff fluid and check the drain plug for metal after a few miles if need be
88sasturbotoy
Jan 30, 2026 01:57 PM
A2theK
Jan 10, 2016 10:18 AM
Snort
Jul 9, 2015 03:58 PM
akaphilly
Jul 9, 2015 02:34 PM
ItsJustD
Jul 7, 2015 07:49 AM
