what's the best tool for this small job
Old Jan 17, 2006 | 08:44 PM
Brendan's Avatar
i am going to have to cut my dash to add a couple of switches for my front and rear lights. i don't want to botch it and would like a nice clean cut done. behind the dash there is a plastic frame that looks to be made of ABS or similar and I will most likely need to cut through that as well. what would you all recommend for this?
Old Jan 17, 2006 | 08:46 PM
Cebby's Avatar
Dremel
4x4Lamm's Avatar
Best bet is to use switches where you drill a hole rather than cut out a rectangle.
I have had good luck with a sharp exacto knife, a file and a few hours however.
Lamm
Old Jan 17, 2006 | 09:05 PM
deathrunner's Avatar
square holes= dremel and exacto. Estimated time 15-30 minutes per hole
circle hole= correct drill bit estimated time 2 min
kgcwb44
Jan 29, 2023 10:02 AM
RobotMoose
Sep 2, 2015 05:53 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
izzmee
Aug 17, 2015 10:20 AM
58rennur4
Aug 4, 2015 08:49 AM
