W56c: input shaft bearing
I'm doing a rebuild on my w56c. I got a repair kit (BK162WS), expecting it to be correct.
Going into the tranny, I find the input shaft bearing is 35TM11NX1, which is 23mm wide.
The input bearing provided in the kit is 21mm wide.
Researching this further, I noticed there is an exception for kits with a factory rebuild where
the outer race is HR6307NX, and the inner race is a 35TM11. On mine, the outer race is labeled
35TM11NX1, so this does'nt appear to be the case for me.
I've researched and tried to work out what variant I have to no avail.
Help appreciated.
Help appreciated.
It's just a throw out bearing, they almost all squeal at some point... just drive the thing. 99.9% chance you'll be fine. Replace it when (or if) it fails
