um.. help
Old Nov 18, 2007 | 07:17 AM
algranger's Avatar
um.. help
i just ran seafoam through my pcv hose and it did everything they said but there is motor oil in the throat of my carb im scared i screwed something up can anyone tell me whats going on. what should i do? can i drive him? also how would i go about cleaning the motor oil out of my k&n filter? the oil shot up the throat and coated the top of the airbox and most of the filter.
Old Nov 18, 2007 | 09:17 AM
tc's Avatar
tc
I wouldn't be worried about it. Carb cleaner will take care of the carb, clean and reoil (LIGHTLY!) the K&N - both items that will help with why you Seafoamed in the first place.
Old Nov 18, 2007 | 10:12 AM
808derek's Avatar
if oil shot outta your carb you might wanna do a compression test to see if you have blow by... i had oil shoot outta my breather on my valve cover into my airfilter and that was what i had
Old Nov 18, 2007 | 05:27 PM
algranger's Avatar
thanks guys. i got the carb all cleaned up, how do you clean the filter though? is it the same as one in an mx bike? can i use the same cleaner and oil? if not what should i use? btw the truck is running even better now, ill have to say i was pretty worried when it wouldnt start and i had oil shooting up out of the carb. i got a lot of weird looks with the smoke too it was fun. gas mileage has a noticeable difference usually after an hour or so of driving around i could notice a drop but after 2 today it looks the same.
Anubiscougar
Mar 31, 2011 08:10 PM
mokai
11
Aug 15, 2007 09:00 PM
Anubiscougar
May 3, 2007 07:09 AM
