stripped and spinning bolts
So I went to loosen the bolts on my powersteering gearbox tonight and I had my huge bar loosening them. I felt it come loose so I kept cranking and it eventually got easier to turn so I put it on a smaller drive and cranked faster...well I soon realized that the bolt wasnt moving out, just around. Didn't know what to do so I went to take off the other one. Started crankin down and slipped off...slipped off again..and again...then stripped. So I said forget about it and called it a night.
Now I've got 2 bolts plus one more that I havent tried yet that are attached to my Powersteering Gearbox and the frame. One is turning in the hole but not coming out, and the other one is stripped. I am gonna try to pound a socket on with a hammer on the stripped one..but what do I do with the one that isnt coming out? Will that one just pull out? Will I have to re-tap that hole? Any ideas would be nice, thanks.
Originally Posted by miket223
Did you try putting another wrench on the other side of the bolt where there is a nut?
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
pyramid
Jul 30, 2015 10:05 AM
