Need help dianosing a problem
car stalled going 65 MPH, It jerked and hesitated for a couple seconds, then shut down.
Pulled a number 12 Code: "RPM Signal" what does that mean?
Trouble area: Distributor circuit, Distributor, Igniter Circuit, Igniter, ECM
How can I check these areas? My Haynes just tells me how to remove them, not how to test them.
The vehicle is not getting spark, I tested the Coil and it was within the recomended resistance (BUT JUST BARELY). so that shouldn't be teh problem....
Any HELP IS APPRECIATED?
Vehicle 94 toyota Camry 4Cyl (5S-EF)
THanks!!!
THanks!!!
theking11863
Mar 19, 2016 09:36 PM
