my yoda is smoking out the tail pipe
Old Feb 11, 2010 | 04:56 PM
boyblue's Avatar
i have an 84 yota 22r and its smoking only when i get on it and cold start any ideas valve guids or rings or both or what elce can it be???
Old Feb 11, 2010 | 05:08 PM
tj884Rdlx's Avatar
what color is the smoke?
if it's bluish, at startup, it's probably valve guides like you said. leak down test will confirm this.
if it's not bluish, but white, it could be your HG starting to fail. check the top of your oil cap and your rad. cap. if you're due for an oil change soon, go head and do it so you can check the oil for the warning signs of milky coolant/oil mix. a block test will confirm this.
good luck.
Old Feb 11, 2010 | 05:23 PM
boyblue's Avatar
its not a blown head gasket... i already checked that and ya it bluish woul it be rings at all???
Old Feb 11, 2010 | 05:43 PM
1989toy4wd's Avatar
It could be the rings, mine did that before I had the engine rebuilt, it was pretty tired. A little bit of bluish smoke when you first start it up after it sitting for a while is valve guide seals. White smoke at start up when it sits for a while is usually just condensation in the exhaust burning out. now if the engine is warm and you get on it and it smokes, its probably rings, just keep an eye on your oil level.
You also said it does it when the engine is cold, it could just be that your engine is running rich, need to do something with your carb!
Old Feb 12, 2010 | 08:40 AM
tj884Rdlx's Avatar
it could be rings. but the leakdown test will allow you to isolate the problem specifically.
do a search for compression testing and leakdown testing. they will each explain how adding oil to a cyl. during the comp. test can tell you if its a ring problem; or "rocking" the cyl. around TDC during the leakdown test will tell you if its an intake, exh. valve, or cylinder leak.
there's lots of info on these tests and i'm pretty sure you can "borrow" the testers from auto parts stores everywhere.
mine was rings. that's why it's off road right now. =(
good luck.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
dzldust
7
Oct 6, 2015 05:39 AM
Scotttekoch
Sep 28, 2015 10:30 PM
charlie_fong
Sep 27, 2015 10:06 PM
