The Innova 5310 OBD2 Scanner helps you easily find the problem & fix the problem.
Old Aug 29, 2025 | 10:47 AM
Innova Scanners's Avatar
FormerVendor
Amazon.com"><span style=Amazon.com" /> Amazon.com">Amazon.com
Innova.com
Reads & erases Engine/Transmission, ABS, and SRS OEM and generic diagnostic trouble codes:
The Innova 5310 provides comprehensive diagnostics for Engine, ABS, and SRS modules, allowing you to identify and address critical issues with ease. The 5310 delivers accurate information to help you make informed repair decisions quickly and confidently.
Code Severity Levels: Quickly identify if your vehicle needs an immediate fix or if it can wait until you get home to fix it yourself.
Smog Check LED Indicators: Find out immediately if your vehicle will pass an emissions test.
Freeze Frame Data: Display all vehicle information from when a trouble code was triggered.
OBD2 Live Data:
Access and analyze real-time data from multiple systems simultaneously. The clear and customizable live data stream aids in identifying issues and monitoring repairs effectively.
Drive Cycle Procedures:
The Innova 5310 simplifies emissions readiness with its Drive Cycle Procedures feature. This function guides you through the necessary steps to complete a drive cycle, ensuring your vehicle is ready for smog and emissions testing. By providing clear instructions and real-time monitoring of system readiness, the Innova 5310 helps you achieve accurate results and avoid failed inspections, saving you time and effort.
Supports All 10 OBD2 Modes: Get unparalleled access to global OBD2 systems, functions, and information.
Battery/Alternator Test: Perform battery/alternator Tests for gas & diesel vehicles.
Oil Light Reset: Reset your oil light.
Make sure to visit our coverage checker to see which advanced functions will support your Lexus:https://www.innova.com/pages/coverage?ad=aaa
__________________
#1 Diagnostic Tool Brand
Phone: +1 800-544-4124
Email:customercare@innova.com
Live Chat:Click Here
Monday - Friday | 6AM - 6PM PST
Innova Scanners
May 20, 2025 11:33 AM
Innova Scanners
May 20, 2025 09:53 AM
Innova Scanners
May 1, 2025 03:19 PM
Innova Scanners
Mar 25, 2025 09:12 AM
Innova Scanners
Mar 17, 2025 02:20 PM
