How Do I use the Plastigage on my 1991 Toyota pickup?
Old Apr 23, 2014 | 12:38 AM
rydholm11211's Avatar
I am doing a top end rebuild on my Toyota 22re, and while I was doing that I was going to drop the oil pan and inspect the crank and rod clearance with a Plastigage, When Looking at the plastigage what number Should I be closes to on the scale? Thanks.
Old Apr 23, 2014 | 04:25 AM
Rowdydudeman's Avatar
check the FSM for bearing specs. there are like 100 different thicknesses of plastigauge also, you need to use the right one or it will throw the reading off.
Old Apr 23, 2014 | 05:41 AM
I was going to use the green one. What do people on here use for the 22re?
Old Apr 23, 2014 | 01:12 PM
wyoming9's Avatar
Red face
It really is only meant for new bearings and clean journals
Any oil will render the plastic gauge useless.
Get what ever color you need for the clearance you should have.
Old Apr 23, 2014 | 02:43 PM
+1 different thicknesses are for different bearing clearances.
Old Apr 23, 2014 | 07:06 PM
Screw it, I will just assume they are good, the truck had low miles, and I did not hear anything. I just wanted to get a visual inspection to see what the journals and bearings looked like.
Old Apr 24, 2014 | 03:08 PM
wyoming9's Avatar
Red face
I don`t think I used Plastigauge since the early eighties.
Now I use a inside and outside mike and subtract.
zd92655
Mar 6, 2022 12:58 PM
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
bprice0077
Jun 25, 2015 07:36 AM
