Fuel Door Key
Old Nov 21, 2024 | 07:26 PM
bufbooth's Avatar
Fuel Door Key
Hello, I have a 1991 Toyota Pickup 2WD regular cab and the fuel door lock is broken.
Do those fuel door locks only work with the truck's exact ignition key, or are they a bit generic (that is only uses a pin or two of the key)?
That is, if I get a used lock from the same year truck (1991) should my ignition key work on it?
Thank you....
Old Dec 26, 2024 | 04:54 AM
loulu3's Avatar
On many vehicles, the fuel door lock is a separate lock that may or may not be linked to the ignition key. Sometimes it uses a separate key, but in other cases it may be designed to be activated by the same key as the ignition (with a single hook or a generic key).
SeaWulf
7
Jan 6, 2014 10:14 PM
CW5150
Dec 23, 2012 11:34 PM
BajaRunner
Nov 16, 2010 03:13 PM
kzink
Aug 29, 2010 10:54 AM
Anton
Aug 14, 2003 10:11 PM
