front end alignment gone bad
Old Feb 27, 2006 | 02:24 PM
bflooks's Avatar
i put my front spacers in this weekend, so i took it for an alignment today. well, it went from tracking pretty straight to...
the wheel now at 11 o'clock and pulling hard right. where did they go wrong here? i am going back tomorrow, but would like some insight as to what the could have screwed up. the pulling hard right is one thing, but my steering wheel now being off center is aggrivating to say the least.
this is on my 98 4runner. thanks!
Old Feb 27, 2006 | 02:39 PM
eric-the-red's Avatar
The wheel is off centre because they adjusted the toe using only one tie rod instead of both, and then they were too lazy to correct it. Pulling is usually from uneven camber or caster, I can't remember which one.
Old Feb 27, 2006 | 04:01 PM
bflooks's Avatar
gotcha. that helps. i have since calmed down after driving hte thing home and am reading up on it, but i am still aggrivated and would like to know all hte lingo before going back so they will listen rather than suggest.
Old Feb 28, 2006 | 03:52 AM
bamachem's Avatar
do your research and take it back.
http://www.automedia.com/Align/It/Yo...cr20021201ay/1
Old Mar 9, 2006 | 12:59 PM
hockeybird's Avatar
Yah the steering wheel is because of the toe adjustment.
Caster and Camber will both pull.
Caster will pull to least negative side and camber will pull to most positive side.
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
toyoda8488
Jul 5, 2015 10:18 PM
