so i was removing the stripped bolt on the crankshaft pully (cutting it out with a cutting disc) when i accidently went a little too far into the crankshaft....do i need to replace it or will it be fine here is a picture:
there is a better pic now....this camera sucks at nighttime with the glare.....if thats still not good enough let me know
the slice across? I would use it, looks like the threads are ok, just run a tap in to make sure and clean up the sharp edges with a little file.
