centering the front wheel
Old Apr 23, 2017 | 12:13 PM
AAMoussa's Avatar
Hi,
I just upgraded my 2010 tundra suspension to King OEM Coilovers with Camburg A-arm. Now, the off road shop cannot not center the drivers side front wheel in the fender well; the tire rubs when I back up. They managed to center the left side. I spoke with their alignment special, he said it cannot be done because it will not be alignment, is this true?
I have 35" wheels on my truck. Prior to the upgrade, I had leveling kit and there were not rubbing. Cannot you provide some tips?
Old Apr 23, 2017 | 02:21 PM
Co_94_PU's Avatar
If they can get one they should be able to get the other. Maybe a part defect, bend frame or need to tweak the installed parts
Old Apr 23, 2017 | 03:00 PM
dropzone's Avatar
Fossilized
Originally Posted by AAMoussa
Hi,
So I am confused, or is this a right hand drive Tundra? They can't center the driver's side (usually the left side) but they managed to center the left side...
Have you owned the truck since new? any record of front end damage? Did you have it aligned prior to the lift so you have previous record to go from?
22R88
10
Jun 1, 2017 06:46 AM
jdmhiluxsurfer
May 20, 2017 10:06 AM
jiju1943
Apr 21, 2017 09:27 PM
jkgts1
Apr 10, 2017 10:17 AM
Neemox
Apr 9, 2017 07:12 PM
