Tips & Tricks Tips and tricks to make the site easier to use such as posting pictures, where to host them, and avatars
Leaking auto tcase
Old Jan 3, 2018 | 06:45 AM
Kadi96915's Avatar
Leaking auto tcase
Ok so my 94 toyota pickup 3.0 auto is starting to leak alittle more on my tcase. My question is do i have to remove the entire transmission just to remove the tcase to rebuild it. Its an auto trans. Pls any info would be great. Thanks.
Old Jan 3, 2018 | 12:08 PM
coryc85's Avatar
Kadi - I don't know much about the automatic trannies, but I would assume the tcase can be unbolted from the transmission and removed. Can you tell where it is leaking from? May not need to drop it, if it is leaking from either of the output seals or perhaps from the drain plug, with any of those leaks you could fix the issue while installed in the truck.
Old Jan 4, 2018 | 06:24 AM
Kadi96915's Avatar
the output shaft seal is 1 leak but there is also another leak on the front 4x drive shaft and also the gasket area. I will also do the tranny pan gasket the same time i do the tcase. Just want to get all the leaks out of the way so i dont have any future problems. Thanks for the info now i can start on it in the next 2 days
jener8tionx
Aug 11, 2011 05:42 PM
dirtykaw
Feb 28, 2011 04:19 AM
Cebby
Dec 28, 2006 07:06 AM
FCRunner
7
Feb 11, 2006 06:19 AM
