Sponsored by: CARiD
what is the differance between a 4cyl front axle and the 6cyl?
Old Apr 30, 2009 | 05:38 PM
bpayne88's Avatar
ok i know this is a newbe question but i cant find the answer. what is the differance between a 4cyl front axle and the 6cyl. i think the housing is the same, but the third member is differant. how do i know the differance when i go to buy the new locker. and is the ring and pinion, and associated bearings differant? please help!
Last edited by waskillywabbit; May 1, 2009 at 05:05 PM. Reason: Title clarity per posted sticky
Old Apr 30, 2009 | 05:49 PM
dropzone's Avatar
Fossilized
the difference would be IFS
if you are using an axle from a 79-85 Toyota truck it is gonna be a 4 cyl axle.
you might be thinking of the difference between a v-6 and 4 cyl rear axle. a v-6 rear third will have more ribs in the third, 4 spiders vs 2 in the 4 Cyl.
Toyota Differential ID LINk
IFS- front diff is gonna be a 7.5" Ring gear
edit:
here is some more diff information for you to read:
"LPH" (Long Pinion Head) vs "SPH" (Short Pinion Head). by Drew Persson
http://www.pirate4x4.com/forum/showt...23#post1478223
Myth Settled: 8.4, V6, 4cyl, ALL 8" - by Brian Ellinger
http://www.pirate4x4.com/forum/showt...hreadid=228681
Toyota 4 pinoin 6 cylinder 8" diff (30 spline)
http://www.4crawler.com/4x4/Images/Diff6cyl.jpg
Toyota Land cruiser high pinion 8" diff (30 spline)
http://www.4crawler.com/4x4/Images/DiffHP.jpg
Toyota 4 pinion 6 cylinder 8" 3rd from a '96-00? 4Runner (30 spline)
http://www.pirate4x4.com/forum/attac...&postid=436184
Differential Mounting Differences Between Different 3rd Members
http://www.pirate4x4.com/forum/showt...52#post5331552
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
