Sponsored by: CARiD
valve tap
Old Feb 26, 2012 | 11:46 PM
2ndgenrunner's Avatar
Exclamation valve tap
I got a 95 4Runner 3.0 form a friend that recently did head work on it. I have a valve tap. I'm not sure what all he did to it. I had to finish putting on the plenum and the pulley's. i changed the oil b4 i started it. Today after driving it 86 miles i changed the oil again. It had a lot of metal shavings in it. Could the oil ports be clogged? It does not have the tap when it is cold only when it warms up. If any one has any ideas please let me know.
Thank you kindly,
2ndgenrunner
Old Feb 27, 2012 | 12:30 AM
i guess ill half to pull the engine back down to see whats goign on
Old Feb 27, 2012 | 03:48 AM
Bassmastry101's Avatar
If you found metal shavings you might want to pull the pan and see what the bottom end looks like. Are you sure that valve tap isn't a slight rod knock?
Old Feb 29, 2012 | 08:25 PM
bassmastry101 im not sure what the sound is. but i did notice that it only starts making the noise after the engine gets warm. im going to pull the oil cooler down to see if it is clogged. this is my first toyota in several years my first one was a 1979 toyota corolla stationwagen. it was a lot easyer to work with casue of the year. so im thinking the oil cooler isnt cooling the oil like it should. like i said i hear it now after the engine has been running for a few.
thank you kindly,
2ndgenrunner
_Nicco_
Sep 21, 2015 03:06 PM
Obmi
Sep 16, 2015 02:13 PM
LotOMiles
Sep 14, 2015 11:45 PM
Corvoid
Sep 14, 2015 10:10 AM
idadan208
Sep 7, 2015 09:06 AM
