Sponsored by: CARiD
Surging / Hunting Idle - '94 22re
Old May 27, 2008 | 05:54 AM
tommyvdp's Avatar
Hi, I am having the surging/hunting idle problem with a 1994 pickup with a 22re. Here are some symptoms that may or may not be related.
- losing coolant slowly (but was losing it more quickly this winter), the surging idle started around the same time as this
- sometimes burning smell from coolant, but haven't smelled recently
- when brake pedal is depressed, problem is worse
- after continued driving, problem goes away
I have read some posts on this, but if you have any ideas about my specific situation with above symptoms, let me know where to start.
Thanks in advance for your responses!
Tom
Old May 27, 2008 | 06:00 AM
YotaJunky's Avatar
It sounds like you've got air pockets in your cooling system, which may be due to your losing coolant, as you have said. The surging/hunting idle may be due to the thermostat sending off mixed messages because of the aforementioned air in the system.
I would first find out why you are losing coolant.
Old May 27, 2008 | 09:51 AM
tommyvdp's Avatar
Gotcha
Thanks, I will look into it. I have a friend who is an experienced 22re mechanic coming out this weekend, I will have him look at it. Later,
Tom
smthwsn357
May 1, 2024 07:28 AM
montanatruck
Feb 26, 2017 07:07 AM
Ironmike4x4
Feb 3, 2016 11:13 AM
jake_v
Jul 22, 2015 03:17 PM
kcaudill
Jul 20, 2015 12:06 PM
