Sponsored by: CARiD
Previa Problems
Old Oct 25, 2013 | 05:12 PM
raven860's Avatar
Previa Problems
Hi all and I hope I am posting in the right place. I have a 92 Toyota Previa and the blower motor Is fine and the temperature gauge runs normal....But I only have heat when I am driving on the freeway. If I slow down due to a traffic jam or stop I have only cold air. Also I am leaking Antifreeze from somewhere and cannot see where it is coming from. Any help is appreciated. Thanks In advance!
Old Oct 25, 2013 | 05:25 PM
250000_yota's Avatar
The reason your losing heat when you stop is that it's low on coolant, and there isn't enough coolant being circulated when at a stop to keep the heat going to the heater Core. Find your leak, fix it, and the heat should return to normal.
Old Oct 25, 2013 | 05:36 PM
rworegon's Avatar
.....should return to normal after fixing the leak AND filling the coolant back up.
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
