Sponsored by: CARiD
new block in truck doesnt run good
Old Sep 29, 2009 | 05:51 PM
jgt139's Avatar
I just put a new long block into my truck. It ran fine for a little then when driving down the road it felt like the clutch was slipping or something was catching. i went and checked the brakes hubs didn't find anything then i checked all the vacuum lines and electrical connections all are good then i decided to replace the spark plugs and distributor cap it solved the problem for a little but now the problem is back.
Old Sep 29, 2009 | 05:53 PM
olharleyman's Avatar
did you replace the rotor? verify timing with the jump wire?
Old Sep 29, 2009 | 06:35 PM
jgt139's Avatar
yes i replaced the rotor and checked the timing i went out tonight and took out the spark plugs and the plug closest to the cab was fouled i think that would be the problem now a question would be why is it fouling the plug i just replaced them three weeks ago.
Old Sep 29, 2009 | 06:38 PM
are they NIPPON DENSO?
Old Sep 29, 2009 | 06:55 PM
24Runna's Avatar
or NGK?
Old Oct 1, 2009 | 09:43 AM
jgt139's Avatar
the plugs are nkg now they were denso
Old Oct 1, 2009 | 09:56 AM
24Runna's Avatar
How is it running now?
Old Oct 1, 2009 | 03:45 PM
jgt139's Avatar
it is running fine now so the plugs being fouled was the problem now have to fine out why there getting fouled its the third set that's be in there in there since august it fouls the back plug i take it out and it covered in burnt oil. so now i have to find out whats causing that problem don't understand cause its a new block just put in in august
Old Oct 1, 2009 | 04:04 PM
re-torque your rear well all your head bolts to make sure they are at spec.
Old Oct 1, 2009 | 04:13 PM
theAuthority's Avatar
User Requested Ban
the new block, in my truck, doesn't run well ....
Old Oct 1, 2009 | 08:30 PM
brian2sun's Avatar
Is it a brand new long block or a rebuild? Did the long block come with a warranty/guarantee?
Old Oct 4, 2009 | 05:30 PM
jgt139's Avatar
it was a rebuilt long block with a guarantee and the head bolts needed torqued down again
Spicer
Apr 7, 2026 07:17 PM
91toybeater
Dec 27, 2015 07:46 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Badger62811
Jun 26, 2015 09:26 PM
XtremeOff-Road
16
Jun 27, 2002 07:32 PM
