Sponsored by: CARiD
max tire size 265/75/16?
Old Aug 31, 2006 | 01:10 PM
jjrgr21's Avatar
does anyone know what the max tire diameter is that can go on a 03 tacoma and not rub? will a 265/75/16 rub?
Old Aug 31, 2006 | 01:16 PM
jjrgr21's Avatar
came with 265/70/16 stock and does not have a lift
Old Aug 31, 2006 | 01:27 PM
wjwerdna's Avatar
well, sidewall will be .52" larger, overall diameter +1.04", width same, circumference +3.28", and 22.33 revolutions per mile less with the 265/75/16's, when you're speedo says 65, you'll actually be going 67.21...
but I don't own a tacoma so that is just random info i pulled up
Old Aug 31, 2006 | 01:58 PM
oly884's Avatar
Guest
please search, and if you need anything clarified, then feel free to create a thread. This topic is one of, if not the most common Q we get here.
Old Aug 31, 2006 | 02:06 PM
cackalak han's Avatar
Doesn't rub on 4Runners, don't know about Tacomas...
Old Aug 31, 2006 | 02:12 PM
jjrgr21's Avatar
thanks, someone with an answer, anyone else
Old Aug 31, 2006 | 06:15 PM
ecchamberlin's Avatar
I just put a set of 265/75R16 BFG ATs on my wifes 04 Taco and they do rub on the fram at full turn a little bit. Off road it would rub quite a bit I think. It is frame rubbing so not at all a big deal. No pinch weld or fender contact so far which are the real annoying places to get rubbing. It looks pretty good. Just a little more beefy for a stock Taco.
Old Aug 31, 2006 | 08:17 PM
Good Times's Avatar
moved to newbie section...
Old Sep 8, 2006 | 07:26 PM
Sdkfz251/7's Avatar
I got a set of 265/75/16 Toyo MT's on my '00 Tacoma and boy howdy did they rub! Seemed to to really rub the frame when making right hand turns more than left. A 3 inch lift cured this problem.
Ryan
djpg2000
Nov 11, 2020 04:56 AM
jgallo1
Oct 26, 2015 06:39 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
coffey50
Jul 28, 2015 10:55 AM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
