Sponsored by: CARiD
i have afew questions to ask about a 82 dualcab hilux
Old Aug 10, 2012 | 07:22 PM
OLDHILUX's Avatar
hi all and thanks for taking your time to read this a have a few questions to ask.
ok here we go im looking at buying a 1982 dual cab hilux 'ln46' it has a 2.2L ''L'' engine.
what i would like to no.
1.. will a 2.4L ''2L'' bolt straight in? what gearbox do i use..
2.. tyres what max size can i run?
thanks i will add more as i think of it.
if there is anythink i should no about 4x4 plz feel free to add as im only new to this game.
Old Aug 11, 2012 | 03:16 AM
OLDHILUX's Avatar
can anyone help
Old Aug 11, 2012 | 11:24 AM
myyota's Avatar
The 2.4 (22R) should bolt in. As far as the gear box, do you mean transmission ?, if so any transmission from 84 - 88 will work.
As far as tires go, tire size depends on whether you have a lift or are trimming the fenders for larger tires to fit. If you run large tires you will also have to regear for the larger tires.
Old Aug 11, 2012 | 11:44 AM
85TurboRunner's Avatar
I'm assuming he means the 2.2l diesel and he wants to put in the 2.4l diesel.
Can't help you out though we don't get those cool trucks in the US. They probably use the same bell housing though just like our petrol counterparts here in the states.
I think the 2.4 diesel is a direct bolt up in our trucks though.
Most times I wouldn't say this but post over on Pirate 4x4, they are less likely to flame somebody with a diesel question.
Old Aug 11, 2012 | 04:36 PM
OLDHILUX's Avatar
thanks. yes im talking about the diesel engine.
as for tyres im looking for as much lift out of my tyres. i was thinking a 32/12.5
Old Aug 11, 2012 | 04:44 PM
dropzone's Avatar
Fossilized
Keep in mind that the 84 and up transmissions are 4 inches longer than L. Series transmissions
Old Aug 11, 2012 | 09:57 PM
OLDHILUX's Avatar
would 33x12.5R15 be to big?
Old Aug 12, 2012 | 03:18 AM
bigt's Avatar
so do you have a 1l or a 2l engine?? i believe it should be a bolt in change but
www.toyotadiesel.com would know for sure..
my japese 4runner has 4.88 gears stock and i have 31 inch tires.. i cant go above 120 KPH or ill be at like 4 grand rpm... so you might need gearing if you get tires that big.. the axles will handle them... but that engine is going to have enough trouble getting up to highway speeds as is id say...
my 2.4 2lt-e is a turbo version... its a pretty good engine that get a bad rap.. but for economy , parts availability and preformance a 22re gas might be the better choice...
this coming from a guy who sold 2 22re trucks and got the diesel.
Old Aug 12, 2012 | 03:28 AM
OLDHILUX's Avatar
a 1L.. but can get my hands on a 2L... yeah after thinking i dont want 33 maybe a 32's..
do you no what gears are in the stock diff's?
Old Aug 12, 2012 | 04:21 AM
bigt's Avatar
those are the stock diffs..4.88
i have a automatic though
32 i have gotten to fit on a stock 4runner with only hammering the fenders a bit...
Old Aug 12, 2012 | 04:46 AM
OLDHILUX's Avatar
is that for diesel or petrol?
Old Aug 12, 2012 | 05:17 AM
bigt's Avatar
diesel 2.4 2lt - e
gas i had 4.10 with 22re manual and top speed was fine
Old Aug 12, 2012 | 05:21 AM
OLDHILUX's Avatar
I have 2 parts cars both utes and buying a 2.2L dual cab. and the other is a 18R.
Old Aug 12, 2012 | 06:03 AM
OLDHILUX's Avatar
all so what should a compresion on a 2.2L (1L) test read? (on a good engine)
Old Aug 12, 2012 | 06:17 PM
njtrekker's Avatar
OLDHILUX Compression for (1.L) Diesel
Compression pressure STD 30.0 kg/cm2 (427psi)
Limit 20.0 kg/cm2 (284psi)
Variation limit between cylinder: 5.0 kg/cm2 ( 71psi)
Stock gears on the LN46 are 4.88
gearing change maybe the way to go instead of motor change. Does this truck have 4speed or 5. Is it Left hand drive or Right.
32 inch tires should fit with no probelm.
Old Aug 12, 2012 | 07:45 PM
OLDHILUX's Avatar
thanks njtrekker. What gear's should i go with? its a 4 speed. it's right hand drive. sorry i should have wrote im in australia
Old Aug 13, 2012 | 11:57 PM
OLDHILUX's Avatar
in need of some help
Old Aug 15, 2012 | 06:03 PM
njtrekker's Avatar
LN46Hilux
OLDHILUX
Ln46 with 4 speed 4.88 and diesel are slow. but great for bigger tires and climbing. not sure what your looking to do. a 5speed and lower gears would be better for highway driving. would like to see some pictures of your rigs Mate.
Old Aug 16, 2012 | 05:13 AM
OLDHILUX's Avatar
ITS a dd so i cant go over the top with it. i just going to do it up and make it look nice. maybe a little lifted just not sure what to get tho. any help would be great.
Old Aug 16, 2012 | 05:05 PM
njtrekker's Avatar
OLDHILUX
Just my suggestion. Go with 3" lift. 33 inch tires. if you could get your hands on a 5 speed diesel trans. which is available in your country and maybe a set of 4.10 you would have a nice DD. that would cruise a lot faster. At highway speeds. is the diesel 1L in good shape.(runs good). Still want to see pictures. Thanks.
