Sponsored by: CARiD
I can't get my 1988 pickup out of 4wd
Old Oct 25, 2012 | 06:31 AM
1988_pickup_newbi's Avatar
Hello all,
So I need some help. I got a 1988 Toyota pickup 4wd when I moved to Colorado from Florida for the snow. It was snowing last night. So I wanted to put it 4wd for the morning. I turned the lugs, and then put in 4 high and the light came on.
This morning as I was driving I realized that it was just water and didn’t need 4wd. So I went to a parking lot and turned the lugs and couldn’t get it out of 4wd drive. The light would not come off and when I was drive it was grinding
So when I want to change it from 4wd…Should I put the transfer case from four high to neutral then change the lugs and then put it at 2 high?
Old Oct 25, 2012 | 06:38 AM
bjlambert's Avatar
That sounds about right. There's strain on the axles while in gear, so go to neutral on the shifter and 4wd, (chock the wheels) and try turning it then.
Old Oct 25, 2012 | 07:13 AM
snobdds's Avatar
Take the shifter out of 4wd before unlocking the hubs. You may need to move back and forth a few inches to release the tension in the Transfer Case.
mskalmus
May 28, 2017 07:51 AM
Road Bull
Oct 10, 2015 04:55 PM
andrewtexas123
Jul 14, 2015 04:29 AM
cyclist231
Jul 7, 2015 12:56 PM
