Help! Can’t get rid of vacuum leak 3 intake gaskets down
I’ve made a couple attempts at replacing an intake manifold gasket to solve a big vacuum leak. Used carb spray to find it eventually but after a couple tries and resurfacing I’m starting to think the leak might not be the manifold after all.
Any tips for diagnosing / pinpointing leaks?
any tips for getting the gasket right? I feel like I can’t be that dumb
any help appreciated. I need wisdom. Thanks in advance
1986 pickup 22r aisin carb 4x4 manual
used felpro or oem gasket. Tried once with gasgasinch. Torqued to 14 foot pounds. Last attempt went up to 18. bolt pattern center out in stages. Resurfaced on 400 grit belt sander and checked with straight edge. Was pretty warped/ pitted
Jytuarte
Jul 9, 2008 01:52 AM
