Sponsored by: CARiD
Gears
Old Aug 1, 2011 | 10:32 AM
scottclymer's Avatar
Gears
The only input I'm looking for is opinions on if I should go with 4.88 or 5.29 gears. I run 36" tires and wont be going any bigger on this rig.
Are 4.88's low enough to get power back?
Are 5.29's too low, or unnecessary with 36" rubber?
Would appreciate opinions backed with expierience.
Thanks!
Old Aug 1, 2011 | 10:41 AM
RogueYota's Avatar
5:29's and never look back! I dont care if you are running 31's....5:29's is the way to go!
Old Aug 1, 2011 | 10:43 AM
Mike S.'s Avatar
whitch one still gives you good highway speed?
Old Aug 1, 2011 | 10:50 AM
RogueYota's Avatar
yeah with 5:29s and 36's id say freeway would wind the motor out a bit if you wanna do 75mph. but just normal 45-55 no problems.
My old Sami had 5:29's and 33's and I took it on the freeway all the time and it did 75 at about 4500rpm.
After having 5:29's I wont go back....im getting them for my yota. 22R with 33's.
Old Aug 1, 2011 | 10:52 AM
xxxtreme22r's Avatar
well considering 31's came with 4.56. 4.88's should be used for 33's and 35's should use 5.29's. 38's and bigger should use 5.71's. All of which should keep RPM similar on the highway. Not saying it brings highway speeds back as anything bigger then 33's are heavy as heck to turn at any speed regardless of gears.
Old Aug 1, 2011 | 10:57 AM
RogueYota's Avatar
my yota has stock gears and they are 4:10s....
Im running 33's and never touch 5th. I can do 75 in fourth at about 3500.
Old Aug 1, 2011 | 10:58 AM
Good imput. Thanks
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
