Sponsored by: CARiD
Does my truck need to be level for some repairs?
Old Oct 5, 2012 | 02:00 PM
83's Avatar
83
Total newbie question...but I usually work on everything in my garage. I've got an old Toyota now that won't find in my garage, which means it's out on the street, on a slope. Not a big slope, but definitely a slope.
I was going to adjust my carb. Does it need to be level? I mean I know they can work at pretty extreme angles (the stock carbs, anyways), but I don't know if it's cool to adjust them when they're at angles.
I'll need to figure out which way is best to point it when changing the oil too, I guess.
Old Oct 8, 2012 | 08:13 PM
slow-mo's Avatar
If you adjusting the carburetor float height that controls the fuel level, then most certainly yes.
What kind of adjustments were you thinking of?
Old Oct 9, 2012 | 06:12 AM
83's Avatar
83
Ok, thanks. Probably not the float, but I don't know yet. The truck came from a much lower elevation, and also probably just needs everything, including the timing, checked. I get a little backfiring at times, and the high idle (cold start?) doesn't seem to be right.
Old Oct 9, 2012 | 11:05 AM
slow-mo's Avatar
If your talking about rejetting, then no you would not need to be on a level surface.
You mean the carburetor does not maintain or even have a high idle on a cold start-up?
Or that it does, but is not at the right rpms?
Old Oct 9, 2012 | 01:20 PM
83's Avatar
83
Well, it's a stock carb, which I don't think tend to need rejetting...but I could be wrong.
The high/fast idle doesn't seem to kick on when I start it cold. I have to keep my foot on the gas for while before it will idle on its own, and if I don't let it warm up, it will be very "stumbly" for a while, if it even moves more than a few feet at all.
By the way, this is a '78, 20R.
Old Oct 9, 2012 | 08:34 PM
slow-mo's Avatar
hmmm...well, I don't have any Toyota material on the late 70s trucks. I do have info on the early 80s 21R & 22R trucks.
I can only assume at this point that if your OEM carburetor is Aisan, that it could be similar to the 80s Aisan carburetors in that you have a Fast Idle Cam. And that it is not engaging with you enable the choke. That cam will physically hold the throttle plate open a little to aid in warming up the engine quicker. It would do the same thing as what your doing now, in that you are using your foot to raise the idle.
If you do have a Fast Idle Cam, what is common is that gunk gets built up on the spring and prevents the cam from engaging. Or the spring is broken or not even there or is so worn that there is not enough tension on it anymore to work. Or the cam cannot freely rotate because of the same gunk.
Old Oct 10, 2012 | 07:09 AM
83's Avatar
83
Thanks! I have yet to actually take the air filter assembly off and check it out, but I will at some point.
matrad
Aug 26, 2024 08:21 AM
87blyota
Jul 1, 2015 05:26 PM
zytra
Jun 24, 2015 08:14 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
HBoss
Dec 20, 2004 08:45 AM
