Sponsored by: CARiD
can this?
Old Oct 26, 2009 | 07:43 PM
lostINtheSAUCE's Avatar
can this?
can a catalyst converter get plugged and cause the engine to slow down
Old Oct 26, 2009 | 07:50 PM
olharleyman's Avatar
very much so
Old Oct 26, 2009 | 07:52 PM
well i know what im going to be cutting off tomorrow. should i run a straight pipe or adda anew one
Old Oct 26, 2009 | 07:53 PM
hjkmotor's Avatar
ooooooooooooo yes. my buddys heep had a clogged cat, took that sucker off made a HUGH difference. run a straight pipe, if ur local emssions laws allow......
Old Oct 26, 2009 | 07:55 PM
does anyone know if there is a thread that shows me how to do this
Old Oct 26, 2009 | 08:00 PM
just grab a sawzall cut it out and add a piece of exhaust pipe in between either weld it or u clap it welding is the best option but if you don't have access to welder go to the auto parts store and buy a couple of the clamps and bolt them up.
Old Oct 26, 2009 | 08:01 PM
hjkmotor's Avatar
i don't know of a thread but if you have a welder or know someone who does its real easy.
remove the cat, usually unbolts, use flanges on cat or remake flange copies and weld those onto a piece of straight pipe. and rebolt u will have to get new gaskets to go between the flanges.
