Sponsored by: CARiD
95 toyota 4runner 3.4 swap no spark at plugs
Old Jun 28, 2014 | 08:24 AM
Rainieryota's Avatar
I just swapped a 3.4 into my 95 toyota 4runner and im getting spark to my spark plug wires but not spark out of them! What could be causing this? It rolls over and wants to start
Old Jun 28, 2014 | 08:52 AM
I replaced the coil packs with new ones and still same result
Old Jun 28, 2014 | 09:04 AM
rworegon's Avatar
How did you determine spark to the wires? Or, not out of them?
Did you rip all the wires out of the connectors inside the spark plug boots?
Are the spark plug cables connected correctly?
The MAF (and igniter) is connected?
Old Jun 28, 2014 | 12:38 PM
wyoming9's Avatar
Red face
Just how are you trying to measure this?
Coil packs plugged in ?? Connections clean??
Good ground for the ECM??
System Voltage up to 12 VDC plus??
Good ECM?? Correct ECM??
Should give you a few things to check.
Could be the wires are just Fubared
Old Jun 29, 2014 | 09:08 PM
SacRunner's Avatar
First, try posting here: https://www.yotatech.com/forums/f160/
Second, who made your conversion harness? You? ORS? TOS? another shop?
Follow the signal path from the plugs back to the ECU, is the igniter outputting all the correct signals? If not, is it receiving the correct signals? If not, look to your ECU and verify it's receiving the correct signals and outputting the correct signals.
You're going to need the EWD and FSM for both your truck and more importantly for your donor. Being that it's a 95, its a Tacoma, the various models/body styles had different ECUs so make sure you download the correct versions of EWD for your ECU.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
94whiterunner
Sep 22, 2015 07:25 PM
Edionne13
Jun 21, 2015 11:37 PM
duckhead
3.4 Swaps
7
Jun 18, 2015 06:54 AM
