Sponsored by: CARiD
92 Toyota pickup 2" or 4"
Old Jan 16, 2017 | 10:01 AM
Right_meow's Avatar
^ Stock height with 31s
^ I put a 1" bj spacer and a 2" block in the rear for an over all 2" lift. I did skyjacker nitro 8000 struts, and fox 2.0 shocks (way to stiff). I needed all new tie rod ends, idler arm, wheel bearings, steering stabilizer, lower passenger ball joint. And then had it aligned.
I'm eventually goin to swap out the stock springs with the chevy 1/2 ton springs and get rid of the rear blocks. I can't decide and just putting 33s under her and maybea inch body lift. Or do a 4" rough county lift with 35s.
This red tuck has a 3" lift with 33s
This grey yota has a 4" lift with 35s.
i don't go rock crawling really. I do a little mudding/adventuring it the woods, I'd rather go ride my dirt bike than go 4x4ing but what do you guys think
