Sponsored by: CARiD
86 pick up 22r will not start in the am without starting fluid.
Old Apr 5, 2015 | 12:55 AM
gardnervillegreen's Avatar
I have a 1986 Toyota with a 22r engine. In recent weeks the only way I've been able to start it in the morning is to add a shot or two of starting fluid to the carb. Need some ideas on how I can correct this problem.
Old Apr 5, 2015 | 01:12 AM
wyoming9's Avatar
Red face
Welcome!!
How about a little back history just what have you done trying to fix this so far??
Once the vehicle has started the first time are you good to it is parked for a long time again??
Off the top of my head ignition or fuel.
Bad needle valve allowing gas to siphon out of the carb
Carb problem allowing it to drain into the engine over night getting any fuel in the oil?? Notice any external fuel leaks or fuel mileage in the single numbers.
plugs tired and worn or fouling to the point they don`t want to fire after sitting and getting cold. Might also just be in need of a good tune up.
What do the plugs look like??
As starting fluid burns hotter
Old Apr 5, 2015 | 06:36 AM
AR_yotaing's Avatar
My 79 had the same problem and it was a small fuel leak on carb. You may not have a carb but could still be a fuel leak.
Old Apr 5, 2015 | 09:47 AM
After I start it and it warm's up it will start up again unless it sits for an extended amount of time say 90 min. or so. I haven't noticed any fuel leaks or bad fuel mileage. I removed and cleaned the plugs and found they were still in good order. I've cleaned the carb and the choke. I'm thinking something with the carb/fuel because using the starter fluid you just replacing fuel its not getting correct.
Old Apr 5, 2015 | 10:31 AM
AR_yotaing's Avatar
Yea that's about what mine was doing. I also readjusted the carb. Not sure if that could help or not
stagger_lee
Mar 29, 2016 06:27 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Jake 85 sr5
Jul 1, 2015 06:49 PM
slider417
Jun 22, 2015 10:18 AM
