Sponsored by: CARiD
1994 toyota pickup 4x4 v6 starts for a sec then dies
Old May 3, 2011 | 10:01 AM
tacoma83's Avatar
ok so ive noticed that when starting my truck the first time u crank it over it pops off for a few seconds then dies....ok if u do not turn the key all the way back to off it will not pop off it just cranks over...if u turn the key all the way off then try it, it will pop off for a few seconds then dies. its like its resetting or somthing....any ideas would be appreciated thank you
Old Jul 20, 2011 | 04:16 PM
toyotakid's Avatar
mine is doing the "exact" same thing. i have an 88 yota 4x4 v6 3.0 .... did you figure the problem out at all?
Old Jul 20, 2011 | 05:11 PM
tacoma83's Avatar
We found out it was a bad ECU..found one at a junkyard for like 40 shipd to the door...it fixed that problem for me...good luck and i hope that helps...
Old Jul 20, 2011 | 05:15 PM
toyotakid's Avatar
thanks...so to switch the ecu do you have to do anything special or can you just unplug the old and plug in the new and go?
Old Jul 20, 2011 | 05:21 PM
tacoma83's Avatar
http://www.car-part.com/ i think this is were i got my used ecu from....make sure your numbers match on the ecu's....thats it man.... may want to unplug the negitive battary cable b4 u put ur new one in......
tacoma83's Avatar
let me know if that works...
Old Jul 20, 2011 | 06:08 PM
toyotakid's Avatar
alright will do. thanks a lot!
Old Jul 20, 2011 | 06:15 PM
tacoma83's Avatar
No problem man
Old Aug 10, 2011 | 07:27 PM
jonnyeliguk's Avatar
similar
I have a similar problem, mine would start run for a few minutes then die, then, it would start and then run for say 6 seconds at idle then stumble die, or if you pinned the gas half the time at higher revs. Then sometimes after flogging the starter like a rented mule, she would catch and behave until I let her sit over night or for a longer period again.
Any of this similar to your experience?
Sep 4, 2015 09:27 AM
corey519
Aug 12, 2015 11:12 AM
Jonny246
Jul 24, 2015 12:37 PM
smiley52
Jul 11, 2015 05:16 AM
