Sponsored by: CARiD
1991 4runner.Runs only with Fp to b+
Old Feb 7, 2010 | 08:45 AM
toker_ace's Avatar
Hello everyone.I need some advice please. !991 toyota 4runner V6. Runs with fp to battery but dies when I remove the jumper wire. Is there a fuel pump relay.Please help!! Thanks
Old Feb 7, 2010 | 10:01 AM
Green93's Avatar
The circuit in the AFM tells the fuel pump to turn on. If you have an FSM then go through the testing procedure to make sure it is working correctly. Or if you have a spare sitting around just swap it in to see if that solves your problem. The reason it works with the terminals jumpered is because you are taking the AFM out of the equation.
I had the same problem. One day I started my truck and it would sputter and die over and over. Eventually all it would do was crank and crank.
Jason
Old Feb 7, 2010 | 02:26 PM
toker_ace's Avatar
call me dumb.... but what is the AMF and the Fsm? My B+ is not hot with the switch on, But is hot when it cranks (with the FP run to the +battery terminal) thanks for heping.I'm really discouraged!
Old Feb 9, 2010 | 06:44 PM
myyota's Avatar
AFM = Air Flow Meter.
FSM = Factory Service Manual.
choppe777
May 16, 2016 08:00 AM
Odin
Sep 24, 2015 04:38 AM
altydog
Sep 20, 2015 07:37 PM
gp66
Sep 7, 2015 08:29 AM
Badfish740
Sep 4, 2015 04:21 AM
