Transmission Dip Stick
Old May 21, 2006 | 07:13 PM
sschexnyder's Avatar
I Own A 2004 Toyota 4runner V8 4.7 Liter, Would Like To Know Where To Locate The Dip Stick For The Transmission Fluid, Or Where To Obtain Info/diagram.
Old May 24, 2006 | 08:58 PM
TechWrench's Avatar
You have the 5 speed trans, and if I'm not mistaken, there is no dip stick for it. I believe Toyota removed the dip stick from the '04 and newer 5 speeds. The fluid is supposed to be 'good for life', and the only way to check the level is by removing a sight plug on the side of the trans.
If you do a search on the topic, you should find several older threads on this.
Jun 1, 2021 01:51 PM
crammit442
7
Nov 29, 2017 12:30 PM
Marsheen
Feb 17, 2016 12:29 PM
bfmcelroy
Aug 18, 2015 06:42 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
