Please help w/OME suspension kit!
Hi, I finally got my OME shocks and coils (884/141S front and 895/141N rear) installed on my 4th Gen 4Runner and the driver's side is sitting noticeably lower than the passenger's side when viewed from the rear of the vehicle. Can anyone confirm that the driver's and passenger's side coils are identical in height and spring rate? The OME packaging contained no info that there was a difference between the driver's or passenger's side coils for the front or rear. Any help would be appreciated.
Thanks!
Thanks!
a couple things come to mind: gas tank, battery, driver
this is a known issue even when in the stock form so there's no way around this. One option is to add trim spacers to level it out if you wish. Not sure how popular this is but that's an option.
good luck
this is a known issue even when in the stock form so there's no way around this. One option is to add trim spacers to level it out if you wish. Not sure how popular this is but that's an option.good luck
FS[PacNorWest]: Take off Tundra and other Toyota Parts
justdifferentials
Sep 8, 2015 03:13 PM
Sep 4, 2015 09:27 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
