Battery Light ??
Old Jun 5, 2007 | 12:24 PM
cimahar's Avatar
Battery Light ??
I have looked and have not seen any post for the 4th gen 4Runner Battery Warning light , My light came on, but I have no problems, everything works
fine, any ideas ???
Old Jun 5, 2007 | 12:47 PM
rdlsz24's Avatar
It could be your alternator starting to go out. At least that's what it usually is on the 2nd gen pickups when the battery light stays on
Rob
Old Jun 6, 2007 | 07:47 AM
TheBlueWave's Avatar
Rob
For most cars, the battery light is a voltage indicator. Get a multi meter (or volt meter) and test the voltage on both alternator poles while the engine is warmed up and idling. It should register at least 12 volts. If less than 12, your alternator isn't working right or you have a bad connection at the poles.
If you register a healthy voltage, your light may be screwed up or something else is wrong.
Old Jun 7, 2007 | 02:09 PM
JGage's Avatar
There is a battery warning light? My battery took a dump last month, not light ever showed up.
Old Jun 12, 2007 | 06:13 PM
Skrillah's Avatar
Yeah...sounds like the alternator could be toast or toasting as we speak.
Yota.Jay
28
Oct 22, 2015 01:08 PM
AkitaDog
Sep 1, 2015 08:05 AM
mluz013
Jul 24, 2015 12:31 PM
Sandman
Jul 14, 2015 12:36 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
