16X8 that will fit the 05 tacoma
ok so i have been searching and cannot find anything regarding specs of a 16X8 wheel that will fit the 05 tacoma . Im looking for a wheel that will support a 33X12.5 tire . What backspace and offset should I get to have minimal rubbing? Im going with a 3" revtek spacer lift and dont mind doing some trimming . Please help me
I have been trying to get help on ttora but people are slow to respond and dont seem to have much information to help
Aaron
Aaron
did the 05's come standard w/ 16's? if so, then I suspect you should be fine. I'm guessing the taco's have the same discs as the 4th gen's SR5 discs and I know the 4th gen SR5's brakes are smaller than the xreas(sports/limited) ones so 16x8 will be fine. I have 16x8 0 offset 4.5 BS (American Racing AR-23) so that should give you some heads up. btw tires are 285/75/16 MTR's.
Good luck
Good luck
foampile
Dec 18, 2022 01:29 PM
BeMiceElf
Oct 10, 2015 09:40 PM
