Welding ?
Old Mar 9, 2007 | 05:02 AM
95toybox's Avatar
Welding ?
Ok I am soon to start building my bumpers. I have a wire welder but have never built anything that needed to be this strong. What type of wire should I use?
Old Mar 9, 2007 | 05:11 AM
Angus1's Avatar
how thick is the steel you are gona use?
Old Mar 9, 2007 | 05:12 AM
mt_goat's Avatar
Check out the Fab shop section:
https://www.yotatech.com/forums/f88/
Old Mar 9, 2007 | 05:18 AM
95toybox's Avatar
Thanks man! 5/16"
Old Mar 9, 2007 | 06:10 AM
Yota Tony's Avatar
http://www.hobartwelders.com/techtips.html#mig
Solid MIG wire (welding with gas) you can use either .035" or .045" wire.
Gasless Flux core wire you have to use .045" wire.
Old Mar 11, 2007 | 06:09 AM
95toybox's Avatar
Thanks man!!
Old Mar 11, 2007 | 06:19 AM
waskillywabbit's Avatar
Open the access panel and there should be a chart there that recommends wire sizes...everything from 0.023 to 0.045.
I use 0.025 in my Pro Mig 135 and 0.035 in my MM 251. You can weld with whatever wire you want and it will more than likely be adequate, but it will take more work and more wire to make a weld with smaller wire.
ladybugRC
458
Aug 21, 2020 10:41 AM
tazman1972
11
Sep 28, 2015 10:32 PM
ktm192k
Sep 24, 2015 03:36 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
