Upper ball joint castle nut size
Old Mar 1, 2010 | 07:43 AM
meta87's Avatar
Does anyone know the size of the upper ball joint castle nut? This is for a '94 4wd pickup. My sockets don't fit so I need to buy the correct wrench. Thanks a lot!
Old Mar 1, 2010 | 08:05 AM
RustBucket's Avatar
I'm 99% certain it will be a 17mm or 19mm
Old Mar 1, 2010 | 08:15 AM
DeathCougar's Avatar
So in reality, you are merely 50% sure its a 17mm, and 50% sure its a 19mm
I am 100% sure its a 19mm.
Old Mar 1, 2010 | 09:46 AM
meta87's Avatar
Thanks guys. Well I stripped the upper ball joint castle nut and can't think of any way to get this damn thing off .
Anyone have any ideas?
Old Mar 1, 2010 | 10:06 AM
RustBucket's Avatar
PB blaster, vice grips.
If you're changing out the balljoint just grind the sucker off.
Old Mar 1, 2010 | 10:07 AM
RustBucket's Avatar
Thank you for simplifying my stochastic model!
krimsonone
Sep 13, 2024 09:33 AM
Sep 4, 2015 09:27 AM
yoder519
Aug 17, 2015 07:12 AM
coffey50
Jul 28, 2015 10:55 AM
ksmudrunner99
Jul 21, 2015 05:33 AM
