Truck has trouble starting!!!Some HELP!!!!
Old Sep 24, 2007 | 05:45 AM
1990arizona4runner's Avatar
I own a 1990 4Runner 4x4 with the 3.0 V6. In the morning I go out to start it and I have to crank it for like 15 seconds. It seems to me like its not getting any gas. I don't think its the cold because I live in central AZ. I have never really worked on fuel injected vehicles to much so im not to sure what to do. It only does it on the initial start-up in the morning. Any suggestions? Is this a common problem with 4runners? What should I do to fix it? The truck currently has 163K on it.
Old Sep 24, 2007 | 05:55 AM
helusay's Avatar
It sounds like you might have a bad cold start injector. They run about $135 at Checker, and they are easy enough to get to that you don't need to remove your intake plenum.
Old Sep 24, 2007 | 07:56 AM
thook's Avatar
It could be the cold start injector, or the cold start injector thermo/timing switch. It tells the ECU what the coolant temp is. If it's below a certain temp, it engages the CSI.
Old Sep 25, 2007 | 09:06 PM
Phroze2006's Avatar
Could be plenty of things try the CSI "cold start injector first" might be a fuel filter or pump
Badger62811
Jun 26, 2015 09:26 PM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
Robinhood150
Jun 15, 2002 12:58 PM
