This is the transmission I just swapped in. It doesn't sound quite right. [Video]
Old May 19, 2010 | 01:26 PM
wilshire's Avatar
I have the transfer case in neutral so I can shift through the gears:
http://www.youtube.com/watch?v=hw5mvM2Q82s
Does that sound right? Doesn't seem like it to me. The guy I bought it from was all gung ho about what great shape it was in.
When I drive around I don't hear it except in first and second gear. I didn't even know it was doing it in all gears until i tried putting the tcase in neutral and running it stationary.
The oil is full, clean, and of the proper type in both the transmission and transfer case.
Old May 19, 2010 | 02:06 PM
c0ugar69's Avatar
i couldnt hear what your talkin about in the vid! it sounded ok from what i could tell.
Old May 19, 2010 | 02:09 PM
MaK92-4RnR's Avatar
sounds normal to me.
Old May 19, 2010 | 02:21 PM
wilshire's Avatar
This is how it sounds when I drive it:
http://www.youtube.com/watch?v=a7Vhw...eature=channel
It's got a bit of a whine to it that I don't remember my old gearbox having. Almost sounds like straight cut gears a little, or like the transfer sounds like in 4LO. I'm on the fence as to whether this sound is normal or abnormal enough to warrant doing anything about. It just seems like there's definitely a whine there.
Old May 19, 2010 | 02:27 PM
iamsuperbleeder's Avatar
the only bad thing I hear is windsheild wipers replace those things man!
I hear a very slight whine, but nothing that I would worry about. What kind of fluid did you put in it? Have you checked to make sure it's full after running it through the gears some?
Old May 19, 2010 | 02:33 PM
MaK92-4RnR's Avatar
oh my god... what're you using for a windshield wiper?
Old May 19, 2010 | 02:39 PM
wilshire's Avatar
Here's one where I rev it a little with and without the clutch engaged. You can hear the whine a little better.
http://www.youtube.com/watch?v=HIeznLe1xRA
The oil in the transmission now is 75w-90 GL5. I forget what brand. I have a few quarts of MT-90 in the garage for the transmission once I find a keeper.
Old May 19, 2010 | 02:42 PM
wilshire's Avatar
Haha. Yeah the windshield wipers should probably be replaced, I know. They work okay. It was spritzing just enough to need them but not enough to lubricate the windshield.
Old May 19, 2010 | 04:43 PM
wilshire's Avatar
Anyone else have an opinion on this?
Old May 19, 2010 | 04:44 PM
I hear a valve tick
Old May 19, 2010 | 04:56 PM
SwampThing's Avatar
What shape was the pilot and throwout bearing when you put it in? That's what I would check cause it seems like the sound lessens when the clutch is depressed. Probably the first thing I would check would be that pb and tob.
Old May 19, 2010 | 05:09 PM
wilshire's Avatar
Brand new, both of them. The whine is coming from the gearbox itself. I'd be less hesitant to write this off as a normal noise if it weren't for the fact that I don't remember my old one doing it. That one was a W56-C (1990) with 177k miles on it. This one's supposed to be a W56-E (1993) with 52k miles on it.
Assuming that the guy I bought it from was being truthful, it only has 52k on it. The clutch and flywheel from it were good. Even the shifter seat was in great shape. It shifts nice and tight. I have every reason to believe it is indeed only 52k miles old, and I just can't imagine you could break one of these in only 52k miles no matter how poorly you treated it. That makes me lean toward this just being normal gear noise. It's really hard for me to tell though.
I don't want to go through the hassle, expense, and risk of another transmission swap because I was having OCD about how this perfectly good transmission sounds. But if it's *not* good, I don't want it in my truck waiting to strand me when it dies and annoying me every day until it does.
Old May 19, 2010 | 05:12 PM
wilshire's Avatar
If I heard it when I depressed the clutch, I'd be sure it was the pilot or release bearing, but it's happening with clutch engaged only. They're brand new, anyway.
Old May 19, 2010 | 05:25 PM
pruney81's Avatar
Every Toyota truck manual transmission I've ever had whines, some more than others. I couldn't really hear anything either except maybe a valve tick like others said.
Old May 19, 2010 | 05:51 PM
wilshire's Avatar
It seems like the Yotatech consensus is that I should replace my windshield wipers, adjust my valve lash, and not fret too much about my slightly noisy new transmission. That works for me. Thanks, everyone.
Old May 19, 2010 | 08:42 PM
c0ugar69's Avatar
just turn the radio up louder. problem solved!!!
Old May 19, 2010 | 08:47 PM
lol, you got it!
Old May 20, 2010 | 04:51 AM
crafthorse's Avatar
Sounds like a normal Jap Tranny to me!!
Old May 20, 2010 | 03:00 PM
myyota's Avatar
The tranny sounds fine to me, but it sounds like your valves need to be adjusted.
Old May 22, 2010 | 04:59 AM
Flash319's Avatar
Sounds fine to me. Its a truck.
