timing problems
Old Sep 22, 2012 | 09:03 PM
AWeissert's Avatar
timing problems
using a jumper & timing light, I set the timing to 5 dgrs. But with the time set like this the engine bogs and or dies whenever i hit the gas. the ecu only shows the 51 code. I had to set my time back to 36 dgrs for any sort of acceptable performance. Could my distributor be the problem?
Old Sep 22, 2012 | 10:34 PM
sechott's Avatar
Code 51 usually means your TPS needs adjusted, this usually means your computer is not getting the idle signal. Easy job if you have mechanic skills, Haynes manual and a set of feeler gauges. Get this worked out before suspecting bad parts.
gillesdetrail
Nov 19, 2019 12:56 PM
the1998sr5
Oct 19, 2016 12:48 PM
jennygirl
Nov 17, 2015 11:24 AM
85run
Jul 8, 2015 11:20 PM
