Supra MAF, need measurements
Old Nov 15, 2008 | 12:44 PM
Junkers88's Avatar
Ok the MAF works. Now I need to hook it up for good. I plan on running some 3"id pipe from the MAF into the fender and up/out near the antenna on the pass side for the snorkle. The problems I seem to have run into are connecting the MAF to the plenum. The plenum measures 2 3/4"od and the MAF measures 3 3/16"od. I can't seem to find a piece of flexible hose or a hard hose with a 90 degree turn that will fit both. I know someone has done this so if you're reading this can you post up some part numbers or pictures of what you did along with where you got the parts? I also need to pick a filter for the top of the snorkle and am looking at a K&N that has the 3"id attachment and is about 5" tall/4 1/2"wide. Is a filter on top of the snorkle a good idea? If not then how can I filter the air unless I can find an inline (really hard to track down) that will work.
I can't believe that now that I found the MAF I can't find the goodies to make it work with the snork.
Thanks in advance.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
voiddweller
Oct 2, 2015 07:47 AM
creecher10
Sep 30, 2015 03:27 PM
93RedKrawler
Sep 29, 2015 02:50 PM
