sucking fuel now 94 3.0 runner
ok so after my blowen head gasket repair which included
recon jnjectors from flamethrower
plugs
wires
some temp sensors
the truck seems to run better than before
but I think I lost my mileage
i did mess with the tps because I had a prevous issue and I replaced the tps and set it on truck so I bench set it but then i messed with it again because I thought it was a problem turned out to be bad ground
last check on tps the main setting was in
but I did not check all the spaecs
looking for any ideas
oh cel is not on and I have not run codes (will there be without cel on )
plugs
wires
some temp sensors
Check all the specs for your TPS. If misaligned then it might cause your MPG drop.
The Flamethrowers don't guarantee better mileage. You might have had clogged injectors or poor spark leading to poor combustion and by replacing it all, improved performance and now it's drawing as much fuel as it should have been in the first place.
Why do I know this? I was running on 5 cylinders when I got the truck I have now. Once fixed, my MPG's dropped from 15.5 to 14.0. Course, I've got it back up to 18 now but that's a different story.
dirtrider0129
10
Jun 24, 2015 12:24 PM
